Solder Wick or Solder Sucker
Started by mike1999, February 12, 2016, 04:31:AM
mike1999
Just for conversation, do you use solder wick or a solder sucker more often? Is wick or the solder sucker better? Or do you see uses for each?
I have played around with both and sometimes the wick seems to work better than other times. i would prefer it if the solder wick worked all the time.
Experience tells me that there is a time and place for everything. I agree that the wick is better for most applications, but if you are removing a larger amount of solder, you can get better results with a good solder sucker. I use both.
Now that I think about it though, I probably use the solder wick about 95% of the time.
luckylou
Any de-soldering I have ever done has been accomplished with solder wick. I prefer wider, heavier wick, I think it just works better.
brenden80
I also would rather solder wick in almost every case of simple board repair. The solder suckers never worked that great for me.
Best Regards,
Brenden
treqilio
I also prefer solder wick vs a solder sucker. I think soldering wick simply works better than the solder suckers.
