What is a Schmidt Trigger?
Started by zigmund, February 07, 2018, 04:09:AM
What is a Schmidt Trigger? I have a position feedback device on the end of the x axis table on a milling machine that hasn't been accurate for a while. I tried swapping the x and Y axis feedback devices and the problem stays with the x axis so it is not the encoder (or whatever type of feedback this is). The machine is old but it doesn't appear to be this unit.
I spoke with the previous owner of the business and casually mentioned the problem. He said it sounds like I've got a bad Schmidt trigger circuit. Any thoughts on this?
Thanks!
Quote from: zigmund on February 07, 2018, 04:09:AM
A Schmidt trigger is a squaring circuit where its output is always a square wave regardless of the shape of the input signal (or input waveform). Schmidt triggers are very useful when converting an imperfect analog signal over to a digital 1 or 0.
I think it is actually spelled something like Schmit or Schmitt.
